bad starting 3.0 td ssrx ltd
  • bad starting 3.0 td ssrx ltd
    I have problem my 1994 3.0 ltd auto starts for 1 or 2 seconds but will not idle can anyone help
    starts but wont run !!
    as in fires up and dies,
    turns over..........may need to be a bit more specific
    if you mean it wont drive back or forward,firstly check the obvious.
    dip the atf fluid,whilst its running and in park.
    also check the transfer lever hasn't been knocked into neutral
    Non intercooled nothing.
      starts but wont run
      engin turn,s over starts but will not idle as you say fire,s and Die,s
        2 questions,
        When were the fuel and air filters last changed ?
        Just what are you using for fuel ?
          starts but wont run
          fuel and air filter changed 2 month,s ago
          BP diesel
            It's worth checking fuel and air pipes for leaks
              Pull the fault codes first, might give you a clue.
              See the Sticky Servicing Thread in tech for details.
                starts but wont run
                after driving back from work some 37 kilometers i parked my pride and joy no problems came back out 1 hour later went to start her and all she now does is fires and dies, engine fault light on dash comes on
                can anyone help
                  Remove the fuel filler cap and try again.
                    could it be bad BP diesel
                      Not really, sounds like fuel starvation caused by a vacuum in the tank.
                        not starting
                        thanks when i pick it up we will try that first Kind Regards Ian PS i will let you know if it works
                          sounds more like an air leak or blockage.
                            not starting
                            only thing is there,s a lot of white smoke and a strong smell of diesel so is it fuel starvation sorry if that sounds thick but im now drowning my sorrows in beer
                              not starting
                              i had to it taken away on lowloader this is going to cost
