heating problems
  • heating problems
    Hi All, while using the surf this weekend i noticed its taking a hell of a long time to warm up, this morning i drove the usual 9 miles to work and the temperature gauge hardly moved and it was only blowing lukewarm air inside. now i know it's been $$$$$$ cold and frosty but surly it wouldn't effect it this much or have i got a problem.
    ps. it's a 1994 3.0td
    Thermostat stuck open, get a new one from roughtrax.
    Without Surf And Unhappy
      Have got the recirculating air button pressed in, or fresh outside air?
        Could just be the tubes are narrowing cos they're full of gunge!!
        I know when i did my rad, all the heating tubes were nearly closed off they had so much crud in them!
        Its worth pulling one off the rear heater to take a look!
          cheers guy's, nothing serious then buy the sound of it. I'll have a look tomorrow and let you know the outcome
            I changed my stat earlier in the year because the temp guage was reading lower then it ever did before.
            Engine gets up to heat in a few moments. An the heaters are warm within 5 minutes. Also seems to hold its heat better after parking an leaving it for xx minutes.
            Well worth doing for the small cost involved.
