Diff Lock 2nd Gen
  • Diff Lock 2nd Gen
    Can any one tell me how you lock the diff on a second Gen ?
    Erm, thats assumin you can lock it.
    Thanks John.
    Thanks John.
    not as far as i know you can't
      Welder?????
      Might have to fit a nice arb one
      www.scottishmudclub.com for scottish events
        Thanks John.
        You'll need an air powered diff-locking kit fitted, expect to fork out around 450 quid for each diff!
          Originally posted by smiffy
          Welder?????
          hehe, Welder cheap, but not very road friendly. Anything else £££'s but road manners acceptable. LSD better than an open diff but not as good as a locker, auto lockers cheaper than manual lockers but clicky on the road going round corners and very unpredicable in the snow or ice, manual lockers are the ultimate, but ultimate money!
          Don't get confused by the Landy guys "I've got a diff lock, it must be better than your truck" rubbish comment, all that does is lock the center diff, same effect as putting a 2nd Gen in to 4H or 4L.
            Does anyone know if its possible to weld the front diff up and retain the selectable 2wd/4wd with the standard Toyota ADD system?
              not unless you want it to go bang.
              www.overfab.uk
                Thanks for info..I get that from quite a few landy owners
                __________________
                Back in the day Baby
                  Yes it'll work, but it probably explode if you try to shift-on-the-fly and wear part quickly.
                  Fit manual hubs and it'll be fine. but the front CV's are quite weak, especially on full lock. Big tyres and sudden grip will probably granade a CV if the diff is locked and the tyre can't slip.
