Hi All,
I've recently purchased a '95 4Runner, but I think I've not been sold and all together honest example. Apart from the interior lights not working (missing fuse) the trubo light goes on and off seemingly randomly. I've read up on the check connector usage to trouble shoot, but, if the check connector is supposed to be attached to the relay/ fuse box in the enginge bay, then mine is missing, together with what the other relay / fuse box next to it is supposed to be for. I've found two cables with connectors under the main box, and I am wondering if the two missing items should plug into these. Don't suppose anybody could confirm the location for the check connector, and if these two missing items do connect to connector plugs? Also, if the fuse is missing for the interior lights, does anybody have any thoughts what I should check before reconnecting, as I suspect it's missing due to some other issue.
Cheers in advance for any information.
R.
R.
