As some of you may know a recently bought a surf ssr-g on a 96 which i believe is a 3rd gen (still new to this)
When i got 4x4 home it was dark and was tired after picking it up from kent
I bought it from a guy who had bought it a 2 weeks earlier from a member on ebay called spoon456 i think he's mrsurf here.
Anyway on the monday i noticed a small patch of black oil the size of a 50p coin or a £2, finally i got round to taking a couple of pics and this is the 1st real time i have had to post regarding this.
I took the pics from under the drivers side door not the greatest pics but hopefully someone may know the issue with luck.
In the center under where the engine is located is a metal plate where the drive shafts are now this has quite a bit of sticky oil (might be the gearbox) there is also a white plastic clip that looks like electrics now above that there is quite a bit of oil up their
Question is does anyone know the cause of this?
It only drips as far as i know when the 4x4 stops even for 20 mins and is usually 1 or 2 drops max (50p or £2 coin sized)
Jeep runs fine and is a lovely made machine and don't want to feck the engine up or whatever the leak is from any ideas b4 i have to take it to mechanics
