Just in case any body's interested, received this after contacting mailto:andrew@allisport.com Sounds interesting.
Hi Sam,
Thankyou for your enquiry regarding your Toyota.
We can offer an intercooler system that is designed to fit in front of the
radiator and uses a combination of silicone hoses and aluminium pipework to
connect to the engine. The inlet manifold will need a slight alteration to
accept the extra pipework, which makes the modification difficult to offer
in
kit form.
The power and torque will increase by up to 40% with improved economy and
throttle response. The cost is £555+ vat.
As the engine uses an electronic fuel management system, it is necessary to
use an additional tuning unit to allow us to adjust the fuel settings. This
acts in a similar way to a "chip" but is wired into the loom externally.
This unit is adjustable and allows us to calibrate the settings to match
every individual vehicle. The other benefits are that it can be set for a
standard vehicle initially and then re-adjusted at a later date to suit an
intercooler upgrade, plus the unit can be removed and fitted to another
vehicle. This unit will cost £390+vat.
We are offering a free fitting service, or the kit is available for DIY
installation with an exchange manifold..
I hope this is of interest and look forward to hearing from you.
Best regards,
Andrew
Hi Sam,
in
kit form.
Best regards,
Andrew
