What the safest / easiet way to drain the fluid ?
power steering
i wish to drain and replenish mine as well and was going to do it from one of those pipes down by the searing box under the battery, figuring it would be easier to get to and get more out.
i was wondering if anyone knew how much fluid it takes,
the fluid in the top is cronically discoulered, obviously it gets hot and wears out and needs changing after a few years. hopefully the system will perform better with greater preasure and not blow any seals.Last edited by davemaxx; 12 October 2007, 20:01.
looking at the resevoir this morning i might pull the upper pipe off and put it in a catch bottle and then run the engine and see if i can pump the old stuff out while poring new stuff in, when it starts coming out clean that should be it. it might also pay to have the front wheels off the deck and the stearing turned to one side so a steering box valve is definatly open so there is no restriction to flow,
does this make sence?
Hi Folks,
The Max Ellery manual says drain from the fluid pipes where they enter the box. To bleed it says jack wheels off the ground, turn from lock to lock until all air bubbles are gone from the res.
The steering box I`m about to fit has a bleed nipple?? so if anyone has any more info. on bleeding the system.
cheers,
chrisPowered by Toyota!
looking at the pipes from under the truck, therse a great big u-bend in both pipes running the width of the truck and then up to the steering box, so you aint going to get much out. only whats in the box.
does the manual say, open the bleed nipple and run the engin so it pumps out?
does the manual indicate how much fluid the system holds?
looking down into the resevoiur, there seems to be an anti splash plate thing and i have taken the top off when the engin is running and it doesn't brew over, i havent yet tried it with the stearing turned yet though, i'll have a look later in the week. i'm still pretty confident about pumping it out from up that end, but i doubt wether i can do it until mid week but will let you know how i get on, unless anyone comes up with how they did theirs.
i thought there would have been loads of info on this one becauses its a fluid change and it gets just as much a bashing as any other oil reliant component.Last edited by davemaxx; 15 October 2007, 00:04.
will be interesting to hear results, I'm ready to do a pump re-seal soon.
been leaking ages and i got fed up so ordered seal kit from roughtrax.
I imagine i will have to drain and refill my system too.Alan
I have`nt fitted the box yet but it`s still dripping blackish fluid on the workbench! I would imagine like most other things Toyota, you wont get all the fluids out from things unless you use some kind of pressure or a take out. Kerrsurf- your fluid will be changed just taking the box out. On both boxes I`ve seen now the fluid has been well used so that cant be any good for seals. Looking forward to nice fresh oil in there.Originally posted by KERRSURFwill be interesting to hear results, I'm ready to do a pump re-seal soon.
I imagine i will have to drain and refill my system too.Powered by Toyota!
good stuff, never tackled anything like this before but I got some good info from yota forum.
I'll try and take pics and do a write up.
unless it's already been done which would be a brilliant help.Alan
