Hiya,
Newbie needing help.
I've just bought a surf 1993 3.0td and have spotted rust on bottom of the inside of the the two front doors. I'm guessing this is because water wasn't draining properly. One of them has only just started rusting while the other one (drivers side) has rusted through all along the bottom of the door leaving a long hole (no more drainage problems there then).
What's the best way to deal with this? Is the damage structural or can I just s$$$$e off the rust, primer it and paint over it?
If the damage structural do I need a new door and if so, short of hoping a similar coloured one (burgandy over grey) appears for breaking, where do I get one?
Cheers,
Keith
Cheers,
Keith
This is the only fault I can find with the hilux in it's various forms.
with those $$$$py window strips and stupid little drain holes, probably not painted properly along the seams. Watch the bulkhead too under the skuttle 'cause that goes too! What junk. I'd like to see what was done for the new hilux vigo.
