should the stud end of the idler arm (the bit with the ruber boot on it, and castleated nut) be locked solid, i mean am i right in thinking that the movement part of this component is at the other end where the plastic bushes are housed, and the rubber boot over the stud is only just a cover, and the stud isn't a moving part?
idler arm
Originally posted by davemaxxshould the stud end of the idler arm (the bit with the ruber boot on it, and castleated nut) be locked solid, i mean am i right in thinking that the movement part of this component is at the other end where the plastic bushes are housed, and the rubber boot over the stud is only just a cover, and the stud isn't a moving part?
The castleated nut should indeed be tightened up and then locked with a split pin.
It moves around both joints but the nut isn't locked as such!
I just tightened mine up as tight as I thought appropriate and put the split pin in!
Later!
GaryLast edited by hellmett; 8 June 2007, 13:33.
Originally posted by davemaxxi mean am i right in thinking that the movement part of this component is at the other end where the plastic bushes are housed, and the rubber boot over the stud is only just a cover, and the stud isn't a moving part?
thanks very much for your replies, i was on the phone to rough trax this morning and they confirmed to me that it does swivel, but is also a very tight joint (you won't make it move with your fingers unless its goosed) i was asking this question because when i fitted new bushes the other week and following threads on the forum there was no referance to its service and i asumed it was just a static stud.
the problem i have got is this pulling to the left, i have now found that the lower ball joints have about 7mm lift in them each side and the uppers about 2 or 3 i recon that they are contributing to the problem and need replacing. can anyone give me some tips on fitting both the upper and lower ball joints i can't see the point in only doing the lower ones because the mot is next febuary and by then the uppers ect........
