hi, just bought a 3rd gen ssr-x surf and am a bit worried about the amount of diesel its drinking, I'm only getting 130 km (90 miles) for £20, I'm not pushing it hard either!! is this normal? it has A/T tyres on which I want to change for bridgestone duelers in the hope that this will help, should I be driving with the overdrive on or off? its a 97 3.0 td auto. is there anything else I can do? what are the pros and cons of LPG or veggie oil? any info would be great cheers
3rd gen surf MPG??
90 Miles For 20 Quid Is Not Too Far Off The Mark I Get About 280 For 50 In My 3lt 2nd Gen You Should Get A Bit More Give You Motor A Good Service Change Oil And Filters Check Tyre Pressure And Lift Your Right Foot A Bit I DRIVE HARD SO SHOULD GET A BIT MORE LPG NOT A OPTION VEG OIL HAS PROS AND CONS TRY DOING A SEARCH ON ITLast edited by dyte; 16 February 2007, 00:57.
Originally posted by northcountryboy76hi, just bought a 3rd gen ssr-x surf and am a bit worried about the amount of diesel its drinking, I'm only getting 130 km (90 miles) for £20, I'm not pushing it hard either!! is this normal? it has A/T tyres on which I want to change for bridgestone duelers in the hope that this will help, should I be driving with the overdrive on or off? its a 97 3.0 td auto. is there anything else I can do? what are the pros and cons of LPG or veggie oil? any info would be great cheers
A realistic MPG figure for your truck would be somewhere between 26 & 30
Providing your tyres are correctly inflated (30psi) your not in 4WD, and your engine oil and all filters are in excellent condition.
