Have just changed coolant on my 3.0 KZN130 after much research and helpful advice in old threads from regulars on the forum. However, I baulked at changing the thermostat (thanks Vince for diagram) because my 10mm socket is not a snug fit on the housing bolts, and 9mm is too small. I don't want to round the top of the bolt off. Are they all 10mm? Anybody know?
Thermostat housing bolts
yea definately 10mm as i done mine a couple of weeks ago.i found a 10mm deep socket was better for the bolt underneathand when you go to put it back together again just make sure the thermostat is sat in the housing properly as mine kept slipping out as i was putting the outer housing backhttps://www.facebook.com/groups/henpals/
Done it-just needed courage to turn socket! What a struggle, though-the lack of space on the 3.0 litre makes it a pain-like painting your hall by reaching through your letter box. Still, I've got a week for the skin to grow back on my knuckles. Just hope to Christ it snows next week so I can feel smug.
Originally posted by carrotcruncherDone it-just needed courage to turn socket! What a struggle, though-the lack of space on the 3.0 litre makes it a pain-like painting your hall by reaching through your letter box. Still, I've got a week for the skin to grow back on my knuckles. Just hope to Christ it snows next week so I can feel smug.https://www.facebook.com/groups/henpals/
10mm nuts
Fun hey....I did mine as part of a new head overhaul and i found that on all the nuts and bolts that had to come off i found that a 16 multi sided socket set is a must. Kept all my skin on the knuckles in place done it all in 1 afternoon.LEARNING ALL THE TIME
