MOT Failure
  • MOT Failure
    well just some blown bulbs.. and a offside front upper suspension arm has excessive play in a ball joint...
    how hard is this going to be to change?? or can i just nip it up a bit??
    TeaM BOFA4x4 Mac 2008
    www.bofa4x4.com
    It may want a pump of grease in there too!
      greased it a few weeks ago.. umm more needed?
      www.bofa4x4.com
        Try tightening the nut a bit more, remove splitpin first though!
          Don't over tighten the nut - you'll just make it impossible to undo when you change it. The joints have a taper fit so the nut only really needs to be nipped to get a good mechanical joint. If it's been greased and it still wobbles then it needs changing. Split the taper joint and then there's just 4 nuts hold the ball joint to the suspension arn. The only problem is holding the top arm up - an easy way to do this is to jam something reasonably solid between the arm and the bump stop before you jack the truck up.
          Roger
            cheers mate, how easy is it to split the taper joint?
            <mutter< angle grinder<<
            www.bofa4x4.com
              normally 3 or 4 good strikes to the side of the taper with a hammer, you could get a ball joint splitter but avoid the hal£ords ones...... they are made of cheese!
                jobs a good un, thanks for the help, mot pass!!!
                another 12 months of surfin'
                btw it flew the emissions, running on 50 percent veg! garage smelt a bit thou!!
                didnt know they did a test drive on the mot now??
                www.bofa4x4.com
                  my mot station takes the surf out for a run to check the brakes out
                    The garage where I get all our vehicles tested, has a platform set into the floor which the tester drives onto and stomps on the brakes and a brake efficiency reading comes up on a monitor. Certainly no joy- riding in my truck!
                    the guy even adjusted my main beams 'cos they were pointing at the ground since I lifted the rear suspension.
                      I used to work in the motor trade, the older rolling roads cant cope with a limited slip diff that the surfs have on the rear, the MOT tester has to use a "deceleration meter" (we used to call it a tapley meter) to perform a brake test. It involved driving on the road and braking hard.
                      Modern rolling roads can cope with the LSD and they don't need to take them out.
                      I don't like the smoke test though, it brings tears to my eyes hearing the poor engine screaming on the gov'ner. Luckly the garage I take it to have some mechanical simpathy and dont rev the nuts off it
