ps- i just checked and when i press for windscreen only i still get a faint breeze blowing through vents but not alot , should i be getting zero wind , anyone else has/had this issue
For de-misting make sure hou have the 'fresh air in' button selected and not the 'recirculate the stale air in the car' button pressed. Otherwise you will just get hot and the windows won't de-mist.
today it stopped blowing air to windscreen , it just pours out the centre air vents now, i 'm guessing its 1 cable to sort then
i noticed upon fitting my stereo , it seemed tight pushing it in ( oh !! matron )
i maybe dislodged something pushing , will have to check it out. asap .
well took it apart and yes the cable has turned back on itself and made it brittle . it now bends at the point of pushing the mechanism to open the window vents, i just greased all the workings and now going to try and solder the end of the wire to make it strong again . possibly crimp some kind of small metal tube around the end too. the whole mechanism down by handbrake lever for the flaps is a point for a blob of grease once a year i recon. if this fails i need a new cable and what a job getting it off from the top of where its fixed if it has to come off, failing this i think i will just leave it off with the vents set to windscreen.
A pic for reference.
If you look down by the pedals, just above the foot rest you (you'll need to get on your knees!) will see these white plastic levers. These can get stuck and need to be 'helped' to move into their various positions do direct airflow.
The pic shows the position on the levers to direct air onto the screen.
