Hello,
I've never liked the fact of the Safari or Airflow snorkels coming by the fender and then going up by the A-Pilar. Why make it run over the fender if you can run it hidden?
I'm omitting the explanations of each part of the process, not a genius translating!
Materials used are:
- 1 70mm diameter per 1.5mm thickness inox steel pipe with a 50º bend
- 1m of 70mm flexible tube
- Some clasps
- A bit of protection rubber profile
- Some sheetmetal
- Two metal screws
- A Safari snorkel head
Testing lengths
Cutting a "bit" of metal
Let's cut
Better have to recut than...
And the new paint scheme:
Hope you like it,
David
Materials used are:
- Some clasps
- Some sheetmetal
- Two metal screws
Testing lengths
Let's cut
Hope you like it,
David
) sooner or later, as your idea is certainly a lot tider and nicer than a black blob along the fender, which is the only thing putting me off a safari snorkel..maybe if they colour matched it.
