Having read other threads on this forum I think i may have solved my problem but I would like advice from you guys in case i'm miles off.
I bought my 94 3.0td KZN130 Surf last week and driving home i noticed that a wobble could be felt at times through the steering and the whole steering seemed a wee bit vague.
I checked and adjusted tyre pressures and took the car for wheel balance and alignment.
I got it back and found the problem of wobble was still there but slightly reduced.
The bloke said the tracking was out by a fair bit but having it sorted hasn't fixed the feeling coming through the steering.
I also noticed that when driving in a straight line that the steering wheel is not correctly centered ie: pointing right about 5 degrees.
Am I looking at replacing the steering idler/idlers?
What are they? what do they do and what do they look like?
Thanks in advance for your help guys, hope I can get it fixed.
