Can anyone help with what i should be expecting from my recently submerged surf?
I've had the injectors out, cleared the cylinders and didn't find any obvious amounts of water, stuck the injectors back in, refitted everything and fired it up, once I'd bled the air from the fuel lines it started easily enough and ticks over if a little shuddery, actually a lot shuddery and doesn't like throttle. Most of the water is out of the exhaust now.
If everything is OK how long will it need to run before i can expect it to run smoothly or should it be already?
Will these engines run on 3 cylinders? or can i rule that out.
as it runs can i rule out damage to a cylinder or valves?
Feeling lucky already but not out of the woods yet!
- susspect tony or someone could tell us about brake fluid life, shedule says change after 2 yrs or 40,000 K - is that right????
