Steering problems
  • Steering problems
    Hello
    I have had my Cv boot replaced on the drivers side and the merchanic messed up the job. My drivers side wheel is about 1 inch back from where it should be. A new merchanic thinks that the problem is the wishbone. Are there any other problems which would cause the wheel to be this out od line.
    Thanks
    Originally posted by want2be123
    Hello
    Thanks
    Hi,
    I would like a piccy of the offending suspension - not too close - any chance ? This is the snag with internet diagnosis - ie guesswork. From what you say something has been connected wrongly - this could be dangerous ! Actually I dont follow why any fault with the wishbone could be due to a replacement of a cv boot, unless other work was involved OR (the wishbone) has failed coincidentaly at the same time...no something basically fitted wrongly or damaged since (from your report)
      Havn't we posted about this before? or an I going mad?????
        Do you really want me to comment?
        Tim
