I have had my surf for about 10 months it has always pulled to the left a bit. due to a bit of a bearing noise from the front i have just changed the front wheel bearings (Nice easy job once i made a socket big enough to fit the hub nut) and i have had the tracking done. although this has helped the problem it still has a slight pull. Has anyone else had this problem and have you been able to fix it?
can't go strait!!
Have you tried swapping the tyres around, this could cause a pull.Originally posted by CJ.MehrerI have had my surf for about 10 months it has always pulled to the left a bit. due to a bit of a bearing noise from the front i have just changed the front wheel bearings (Nice easy job once i made a socket big enough to fit the hub nut) and i have had the tracking done. although this has helped the problem it still has a slight pull. Has anyone else had this problem and have you been able to fix it?
Next up after tracking a full front alignment may be required as camber and caster can also be adjusted on these vehicles.
***Hint*** Fill in your vehicle details in your profile, this helps us see what model you are refering to, which in many cases can lead to differing and more relevant answers.Maurice
