The plastic release buttons that you pull to release the back seats have both gone missing, is there any other way of letting the seats down to make space.
I've broken one of mine, so have a similar problem. My solution is either jam a flat headed screwdriver into the place where the seat locks onto the catch (about a third of the way down the back of the seat at its edge), or to use a pair of long nosed pliers to grab hold of whats left of the top of the bit that the plastic button thingy screws onto and pull.
[QUOTE=Slugsie]I've broken one of mine, so have a similar problem. My solution is either jam a flat headed screwdriver into the place where the seat locks onto the catch (about a third of the way down the back of the seat at its edge), or to use a pair of long nosed pliers to grab hold of whats left of the top of the bit that the plastic button thingy screws onto and pull.[/QUO
Many thanks, what would i do without the forum and you clever people.lol
On the top of the seat backs is the plastic thingys. The webbing loops are for lifting the seat bases.
I've been searching all over to try to lift my seat bases. Webbing Loops? where are these then? If I try to lift the seat bases by hand they seem to catch onto something. I've been trying to find something to "release" them. Can anyone point me in the right direction please?
Put your hand down the back of the seat base, the loop should be down there near the centre of the seat.
Thanks again. I don't know where I'd be without this forum!
Thats nice for you! I cant find mine, but have something similar between the seats. Pulling on it does nothing. Is there any other way of releasing the seat bases?
if pulling the tape dont do it, the hard way is undo the 10mm bolts attaching the seat base to the hinge. 2 nuts either side of the hinge. must be something caught in the gubbins. once you got it off it should work normally next time....
