Ect
  • #31
    hi any chance of a peep of that tranny manual?
    somethk@hotmail.com
    cheers
    • #32
      Hi! I hope someone can halp me. Where can the ect computer be found in a Toyota Land Cruiser Prado with a 2L-TE engine? Does it have a separate computer box or is it integrated with the ecu? Thanks!
      • #33
        uk wolf it will only work by changing up a gear if you have got the surf in overdrive otherwise it will do nothing
        Originally posted by UKWolf View Post
        With overdrive on or off ??
        I tried this as a check to see if it was working, but it did not make any difference. Are there any other simple testes to find out if it is working properly ?
        Ali
        • #34
          7 YEAR OLD THREADS!!!! CHECK THE DATE BEFORE POSTING, I'M SURE THAT AFTER 7 WHOLE YEARS THEY MAY HAVE SOLVED THE ISSUE!
          ya get me?
          well, that was a bad idea!
          • #35
            The correct answer was given in post #2!
            • #36
              Epick....
