Hello, bought the contacts and plunger from my local toyota dealers and picked them up this morning, printed off the how-to pdf from the link on here and a couple more besides. Jacked up the surf, put it on axle stands nsf wheel off, broke the clips off the rubber flap things as you do. Tried to unscrew the lower bolt wouldn't budge couldn't get near the upper one as the bulkhead was in the way.
1. Surf is a 3.0 TD 1994 L
2. Do you remove the bolt or the nut i.e. the bit nearer the front or nearer the rear.
3. How do you access the upper nut???? Is it ok to remove what looks like the AT dipstck and that wiring conduit?
4. How do you remove the battery cable, the cover flipped down exposing the copper bolt but then I was lost.
Though the guides help they seem to gloss over removing the motor which is doesn't help as it seems pretty awkward for a novice like me.
