any advice/ thoughts on the following would be much appreciated.
I am Replacing the steering rack bushes on my 96 gen 3 and removing the mounting U bracket on the passenger side (the one that clamps the huge bush around the body of the rack) I find that the bracket upper bolt is a close interference fit - fine, BUT the lower hole is much bigger than the diameter of the bolt which is a at least a couple of mm smaller than the hole through the bracket. Is this right ? I would have thought that the bottom bolt should be an interference fit like the top bolt so why is it much smaller than the hole. The bolts are the correct ones.
cheers nick
cheers nick
