odd sound!!
  • odd sound!!
    I have recently started noticing a strange intermittent noise coming from the engine.
    It tends to only occur around 800 rpm , and again at 1200-1500 rpm. It has a higher pitch than the general diesel rattle, and does not change pitch as i increase the throttle.
    Also, it happens whether the auto is engaged or not.
    It has a rattly whiny quality, and i have been unable to get the damn thing to happen when i've got the hood open.
    Its a long shot, but can anyone suggest possible causes or things to check?thanks in advance
    adam
    "silly keeps you sane"
    Mine does the same thing and it is driving me up the wall it is like a metalic squeal happens just off tickover and goes at about 1200-1500rpm sound like it comes from the gearbox(auto)i think it may be the torque converter plate but im not sure if you sort it give me a shout
    [COLOR=Red]THE RIBBLE REBEL[/COLOR]
      I have some sort of low humming noise coming from mine - very annoying and even noticable over the stereo?????
      [COLOR=Red][FONT=Century Gothic]the unexamined life is not worth living...[/FONT][/COLOR]
        Mine does not make any noises at all.Should I worry.
        Neville
          Neville
          Mine makes loads of noises I can't usualy trace. Last noise was a squeaky tensioner pulley. Think I've got a worn CV joint now. I gave up worrying long ago.
          Nevillef
          _________________
          Nevillef
            Have you checked your exhaust plates as these come lose and rattle or squeeling sound (metal to metal) Had 3 different rattles on mine when i bought it. One was a lose screw on the door sill plate and took agest to locate.
            BEWARE OF THE REAPER
