hi can any one help please i have a surf kzn130 ssr-x and i cant get it into 4wd i did when i first got it but now i does not want to work could it just be a plug or wire?
4wd not working
You don't say whether it is 4wHigh or 4wLow or both that won't operate.Originally posted by skeetmatthewhi can any one help please i have a surf kzn130 ssr-x and i cant get it into 4wd i did when i first got it but now i does not want to work could it just be a plug or wire?
To use 4wLow you must stop, select N or P then 4wLow (on the lever) then back into D again. 4wHigh can be selected on the move upto 60mph providing you are travelling straight but you should ease off the throttle to allow it to change. 4wHigh does sometimes stick both in and out but even the handbook recognises this. It is also not unheard of for the 4wLow lever to be left in neutral, in which case neither will work.
If all of the above check out then there may be a fault in the vacuum system.
I have a guide on how to fault find on the 4wdrive system but it is too big to post to the Forum. Drop me an Email if you want it and I wiil post it direct.
sometimes you can't get 4WD if you are stationary. the switch works on a vacuum and sometimes needs the engine revs to workScubaSurf
The place to be is under the sea
Nil Illigitimi Carborundum
