Well got everything back together after the rebuild however Turbo won't cut in. I've gone through all the pictures and as far as I can see, all the vacuum hoses are in the right place, the turbo pressure sensor is connected, I have removed the turbo and replaced the gasket between it and the manifold so no air leaks there.
Any ideas. The engine runs smooth and quiet however it is gutless as there is no turbo boost. 4WD system works as well so no problem there on the vacuum hoses.
I'm really at my wits end here so any help would be greatly received.
It's a 2LTE engine.
It's a 2LTE engine.
