Originally posted by andyverran
View Post
Trouble starting
Isn't there a balancing valve or something underneath the truck? It often locked up too easily which a colleague of mine said could be a tell tale of this unit being faulty, so I was thinking that this is a development of that fault.....but I do need to check the shoes, master cylinder etc....
Thats the chappie. I basically have enough wrong with my Surf to keep me busy for weeks to be honest, door locks, Aircon, fan switch, leaky rad, rear window, brakes, pitman arm, ball joints.........ho hum!!Originally posted by andyverran View PostThere is a brake proportioning valve above the rear axle that controls rear brake pressure...more pressure under load is how that works..
Yeah, you're probably right, but I have a terrible track record for buying cars that then go wrong, at least I know this one! It won't be such an issue when I get my everyday car back on the road (an old Golf - diesel engine + waterOriginally posted by tashtego View PostTonka, if there's so much wrong with it, it could become expensive...have you thought about putting the cash towards a newer surf? Maybe a 3.0L?...live dangerously...
) as I use my Surf for the rough stuff, but at the moment it's had a daily 70mile hammering for months...
Fuel primer - heated or not?
Hi there, do I need a heated fuel primer or non heated? I'm at work, don't have my car and wanted to order this today and didn't realise there was a choice! Or maybe I'm better off going for the heated one? Millners have them both listed for the same price here(You'll need to scroll down)
Many thanks!
Good point!! The weirdest thing has happened - somehow the problem seems to have gone away! For now at least, the thing starts first time every morning. God knows why this should be the case and no doubt it won't stay that way, but as I'm now spending all my time getting my Golf back on the road I'm really grateful that the Surf is being a good Surf.Originally posted by woodwarm View PostUpdate ????????????
EDIT: Just reviewed the whole thread, which made me realise that I have done some good work on the old girl over the last few months - replaced the rear drums and fixed the rear window - maybe she's just showing her gratitude!!Last edited by Tonka; 12 October 2014, 00:42.
