OK, so beforer we start, yes I've spent a couple of hours searching through the old posts and haven't really found answer's, so here we are, besides if all we did was search through the old posts, we'd never "talk" to each other!!
So the new Surf seems to run reasonably well, however, I have noticed that on steep'ish hills she seems to bog down and then you have to crawl up the other side in 3rd or 2nd gear, it's almost like the turbo switches off! On long gradient it seems to pull well but as I said steeper stuff just kills it. AN example, on a back road, in 3rd gear coming into a tight corner with a steep gradient after the engine just bogged in 3rd, I pulled 2nd and off we went, with the engine revving freely. From memory my old 2.4lt would pull this gradient in 3rd quite happilly.
I have done the ecu diagnostic and the code is 1, for normal.
The EGR has been blanked off
I was looking to bypass the turbo high pressure switch but can't find the schematic for the 2.4 LTE or is this a bogus venture, does the efi use a high pressure switch?
The head has been replaced with a 3l and I am wondering if maybe the valve clearance's could be in need of a fettle?
Turbo lights all good and on the flat and low gradients you can hear and feel the turbo kicking in, so I don't think it's that but she just seems to bog down under certain conditions and my old 2.4lt just wasn't like that.
So if anyone out there in Surf land has had a similar issue or has some pointer's for me that would be greatly appreciated, cos I luffs my Surf and want her well!
or have I just forgotten how to drive them?? lol
