please note i have read a thousand threads regarding glow plugs so sorry if i seem to ask a question asked soooo many times already but having gone through 3 80 amp fuses i really do need some help
i have just installed a kit from roughtrax for the buss bar two plastic insulator bits they went on all good then put new fuse on went to turn on car and fuse blew straight away?? what am i missing here bar is properly insulated as per instructions on here so where am i going wrong??
please any help? what is the sequence for the actual glow plug washers and what type are they supposed to be as i can only assume they are wrong??
really good images too, now i can confirm i have defo wired up the buss bar in the correct way, however i do not have and have never seen them little black things in top of the glow plug screw
. correct sequence for actual glow plug then is glow plug,then [spacer/washer]then buss bar,then nut with top hat thingy on is that right, thank you so so much for all help answers and images.
