Originally posted by andyverran
View Post
Glow Plugs
lol, in this instance I was actually curious and a bit bored today, not done much besides remove doors....Originally posted by Benross View PostYou touting your wares again Andy?!
I don't know which sensor that is and it may be worth knowing if it fixes your issue...
PS parcel in the post this morning with relays..
Well, I tried the relays but it did not change.
Meanwhile my box of service bits arrived from Rough Trax.
I gave it a full service which included the fuel filter and miraculously my surf has cured itself. I'm now thinking it must have been something to do with the fuel filter?
Either way its starting a lot better now.
Cheers for all the help and advice you gave, its a shame we couldn't pin it down to something definate.If I like it, Bushwhacker doesn't. :-)
Originally posted by Benross View PostWell, I tried the relays but it did not change.
Cheers for all the help and advice you gave, its a shame we couldn't pin it down to something definate.Errr...Originally posted by legendgamesmaster View Posttry changing the air filter. had similar issues, changed filter and da-da! was fixed.
Nope. That's for the gauge. ECU sensor is in block above starter motor.Originally posted by Benross View PostHi Nev,
Can you tell me if this is the right part?
http://www.ebay.co.uk/itm/Intermotor...item2ec2d7d621
http://www.toyotasurf.asn.au/forum/v...ic.php?t=14158
This has the Toyota part number for the sensor -
http://www.ebay.com.au/itm/NEW-Toyot...-/300778138754
I'm sure there's an aftermarket part available locally, so search the forum.
If you still have problems then also replace the small o-ring that is on the drain tap, for the water sensor on the bottom of the filter.
Nev.
