This is trivial maybe, but I'm wondering if the so called frost plugs actually ever blow out on the Surfs if water freezes in block or head? or are they actually just core plugs for machining purposes, is it a myth they will protect the engine if only water was used instead of antifreeze mix.
Also wondering how far sub zero would a Surf head (2.4 say) last - with only water in the cooling system, could -5 do damage over a night?
