Breather
I've inspected the breather but on the LJ70 there is a breather at the top near where the petrol car is that runs under the main filler pipe which joins onto rubber on the tank.
The was rotten and I intend to repair it with rubber pipe. I took a picture but its not that clear. Is the breather a one way valve? Could this be causing any of the problems mentioned above? You can just see the start of the rubber pipe on the chassis rail.
