Yeah no probs, the info from ppppppppppenguin isn't what you should use, time the engine correctly, the 3 pulleys are already marked against points on the block, make sure you get all 3 lined up before removing the belt.
Dont even look into removing the pump until you have the belt off and are satisfied that its all lined up okay. It would also be a good idea to get a new cambelt kit while your'e at it.
Once the belt is off, focus on the pump, the pulley can be a bugger to get off as the nut is tight, yoy can get some m8x1.25 bolts and screw them into the threaded holes in the pulley, this locks it and then you can get the nut off.
Once the pulley is off, move everything you can out of the way. Get a clear view of what you are doing, unplug anything connected to the pump, then clean the area thoroughly where the pump bolts the the cam belt area, you will then see marks on the pump and block, make aure the lines join up and take a photo, the pump must go back in exactly the same place.
Next remove the 4 fuel lines at the rear, the bottom inner one can be an arse, either completely remove the pipes or you can slightly bend them away but its best not to.
Once these are out the way unblot the bracket that holds the pump to the block, its 3 bolts total at the pipe side of the pump, they are awkward, youay find it easier to unbolt the 2 on the block and leave the last one on the pump, you can get it out with it still attached.
Then finally remove the 2 that bolt it to the cambelt side, once off carefully work the pump out, it will be tight but be patient, have plenty of breaks and keep cool.
DONT FORGET TO DISCONNECT THE BATTERIES, hope this helps, any other questions feel free to ask.
