Hi everyone,
I was wondering if anyone could point me to the right direction. Because I feel the boost guage tubing is not where it should be. Am I right or wrong?
ps.
(I did the mod on the wastegate actuator, that diaphram by the turbo just beside its label, you wont miss it, it has two bolts attaching it to the turbo)
I have placed 2 washers each on both bolts behind the diaphram of the turbo limiter.
my boost reading is only upto 6-8psi. almost flooring the pedal, just almost.
Here are some images below.
This is what I meant that my engine is a little different from the other 2LTE turbo diesel SSRX I have seen around the site.
a.) black head/black valve cover
b.) the tubings etc are different those near the throttle. I have them on picture.
B.) are the tubings in the right places here? why is this different from the other 2nd gen surfs 2lte that i've seen. they mostly have grey heads/valve covers and the tubings here are quite different.
ps.
