hi guys, newbie here! just got a 92 surf ssrx 2.4TD auto and was all fine for a about 250miles.
then i tried to start it up form cold this morning and was greeted by a very annoying beep and a number of the warning lights on the dash staying lit (t-belt, oil filter, handbrake, a/t oil temp) handbrake light stays lit even when its not on. It all seems to be running fine though, i've a had a local garage have a poke and they said that the alternator isn't charging at all and that this is whats causing the problems.
the car is still under warrrenty from the people i bought it from and i have arranged for them to send me a new alternator in the post cos i am currently living too far away fro them to return it to them.
what i would like to know is. . .
does this sound like a reasonable diagnosis? I dont want to end up paying someone to remove and refit the new alternator if this is not going to sort the problem out.
i had a look through the older forum psots and it seems that at least one person has had a similar problem but i just feel like i need some reassurance at the moment. it had new batteries and timing belt just before i picked it up so im sure the warning lights are not correct.
thanks for any help you can offer!
matt
matt
