Hello All -
Recently replaced the head on my 2.4 2L-TE and despite replacing and/or cleaning the entire cooling system I have still been having some overheating issues. I am now wondering if its something to do with having an incorrect replacement head gasket. Most of the cooling channels match up, but some are blocked off and some only have small holes instead of full diameter holes..... the mechanic (Bahamas Bush Mechanic - not a toyota dealer in sight!) seems to think that is OK but I am not so sure. Unfortunately the same mechanic threw out the old gasket so I have nothing to compare to.
So my questions are:
1) Should every channel in the block have a full diameter opening to the head through the gasket? Or are there reasons for restricting the flow?
2) How do I work out which of the five listed head gasket codes (http://www.toyodiy.com/parts/p_J_199...KPGT_1104.html) is correct for my SSRX (Q-LN130G-GKPGT) with no old gasket to compare to.
Thanks folks,
Edd
Thanks folks,
Edd
