I've just done a 2" body lift and the filler hose is barely long enough. I've measured the filler cap end and I get it to be 42mm inside diameter.
Just wondered if anyone can confirm it's the same size where it connects to the tank.
Also, has anyone found a supplier for this size hose in the past? The nearest size I can find is 45mm, but I'm not sure that'd pull in enough with hose clips.
Thanks!
Thanks!
