I was planning to do the turbo mod this weekend (with the washers) so i temporarily fitted a gunson lo-gauge to determine the amount of boost i am already getting. I seem to be getting around 8-9 psi max boost and the dash turbo light comes on around 3psi. This max boost is higher than i expected, should i leave well alone or still do the mod?
dazza
dazza
no problem so far!
, a washer went on each bolt and a good old blast around the village to try it out. The difference is really noticable on the long steep hills around here. I may still experiment with different thicknesses of washers but it certainly makes a large improvement.
