Turbo mod
  • Turbo mod
    I was planning to do the turbo mod this weekend (with the washers) so i temporarily fitted a gunson lo-gauge to determine the amount of boost i am already getting. I seem to be getting around 8-9 psi max boost and the dash turbo light comes on around 3psi. This max boost is higher than i expected, should i leave well alone or still do the mod?
    dazza
    Non consternationes.
    You can go to a maximum of 12 PSI
    If you overboost the engine it will go in to limp mode and need resetting, I don't know how though!
      dazza
      Let us know how you get on with this ,I am all for letting someone else do all the experimenting!!!
      Eat.Sleep.Surf.Repeat.
        Incidently I have modded mine - I put a washer in and went from 7psi to 9psi, the pressure dropped off when I installed an Intercooler so I did it again and am now running 10psi no problem so far!
          Yea i had a good look at your intercooler at Avalanche along with the many other mods, i dont have a body lift so would struggle to fit one but wanted to tweak the turbo a little. Do you now have more than one washer behind each bolt fixing? roughly how much was it spaced off to achive the initial 2psi increase?
          Dazza
            Dazza
            Daz, stop pi$$ing about & buy a 3rd gen.
              Dazza
              Initially I had one washer (about 1.5mm thick) which gave 2psi - After fitting the Intercooler I had to put in another 2 washers (on each bolt) to boost it back up.
                I wouldn't want to be a girl about getting it dirty though
                    The deed is done, a washer went on each bolt and a good old blast around the village to try it out. The difference is really noticable on the long steep hills around here. I may still experiment with different thicknesses of washers but it certainly makes a large improvement.
                    Jobs also done this weekend=
                    repaired towing electrics after numerous ploughing incidents at Avalanche
                    fitted roof spoiler in anticipation of the new blistering speeds
                    time for beer
                      Turbo mod??
                      Trying to work out what this mod is? Never heard if it before an I'm all up for turning boost up!!!
                      ALL THE GEAR!............no idea!
                        It makes the wastegate open later
                          So where do these washers go? Is there a post on here for how to do it?
                            Here is the link:
                            http://toyotasurf.asn.au/techsite/cheapboost.htm
                            It's a good idea to fit a boost gauge first:
                            http://toyotasurf.asn.au/techsite/boostguage.htm
                              Magic cheers mate will get on that soon
