Guys hi. ive a 2LTE landcruiser, which was fitted with a viscous fan as standard.
ive since removed the old fan and installed a 16 inch electric one. im having cooling problems so the thermostat is out at the moment. im changing the timing belt, waterpump and installing a new thermostat next week, which will be the 88 degree standard one. ill flush out the rad too. (any tips appreciated)
im manually flicking a switch on the dash to turn on the fan at the moment.
the car had aircon. i took it out. the temp switch A in this picture is on my stat housing, as well as switch B.
If switch A was for the aircon, its now redundant, so as an experiment ive hooked it up to the fan relay. however ive been inforned on the Oz surf site that A = opens circuit at 97 deg c then closes at 92 deg c
its the wrong design for what I want
in the European spec surfs i think this is the fan switch? so maybe i could pull one out of a surf or a corolla (ive read)
kind regards,
Redd .
kind regards,
Redd .
