OK, here we go,
Had a long run to France a couple of years ago, did a couple of thousand miles in total and overheated a few miles from home, since then been not to bad but having to top up coolant now and then. As time has gone by things are getting worse and now I can drive all day as long as it dose'nt involve a long uphill motorway drag or a really steep uphill climb (not easy living in the pennines).
I have only just realised that there may be a common denominator.
Chain of events.
1, leak from bottom hose (when hot) repaired
2, leak from top hose (when hot) repaired
3, radiator split on top (when hot) repaired
4, radiator top hose outlet pipe split (when hot) repaired
Now here we go;
Have I got a problem with the water pump as it seems that every time I find a leak or problem it semms to find the next weakest part. Or have I got a problem with the radiator.
Haynes manual mentions squeezing the top hoze and feeiling a build up of pressure. how much of a check is this ? Feeling the top hose I can't detect anything (new hose).
Any Ideas ??
Next thing is new water pump (£40.00) then it will be a new rad (£140.00)
All new filters & oil installed
Cheers Col
Chain of events.
Now here we go;
Any Ideas ??
Cheers Col
