tapping noise in engine
    I've never tapped a tea soon on a rocket cover, so don't know what it sounds like.
    Strange noises at tickover can sometimes be down to leaky or cracked exhaust manifolds.
    haha
    NO MORE MR NICE GUY!
      Originally posted by schrodingers-cat View Post
      Sounds like This
      nope, got new water pump
        Sig lines question/advice, schrodingers-cat wtf is meant by yours.
        Diesel you might want to change yours.
        Brian
          ok
          I put the injector cleaner in and BINGO, I went for a 50 mile run out, 100 round trip and its as sweet as a nut!
          It still fires up instant when cold but takes 3 seconds when hot? why does it not fire up the same hot as when cold? It is not sucking air anywhere and fully serviced?
            Not practical on a 2.4.
            I did turn it over on the 3rd time to make sure it fired up to be honest but only for a second
              You may have struck on something there. Has he done a kid count, maybe one hid in there and is trying to get out?
              Hmm given me an idea next time they drive me mad!,, watch out for the Anglia news at 10 lol
                any ideas welcome, I have put redex through to help with the injector but it was like this before, The timing marks are all bang on too, cant be back flow as it fires up instant when cold
                  Try it with the filler cap off.
                  • #24
                    Pain Is Weakness is a bad track by a band called Stampin Ground or its a phrase used by the yanks to encourage people to join the marines or its what i`ve got wrote on the front of a tee shirt somewhere, take ya pick
                    • #25
                      Written. It's what you have written on a t-shirt somewhere...
                      • #26
                        Sh1t and i try sooooo hard to be literate
                        • #27
                          Hmm
                          I have read about this on some but would this only effect it when hot? I thought that if that was effecting it it would be same on cold too? as it uses fuel it creates a vacuum I guess your thoughts are, I will try it, then if it works I will drill a small hole, thanks
                          • #28
                            It's possibly not that it's hot as such, but that in the act of getting hot, it has been drawing fuel. I'm not saying it's going to be that, but it's a free and easy thing to test.
                            • #29
                              Im going to try it as you said easy and cost nothing, could be right! thanks
                              • #30
                                No that cap off did not work :-(
                                I do know that the longer that it is left when hot the harder it is to start, if I turn it off and then back on within a couple of minutes it is fine but if I leave it 30 mins it has to turn over and over? I guess the time gets longer until its equilibrium and then gets shorter again as engine cools until instant start when cold....any ideas? thanks in advance
