Originally posted by TonyN
View Post
tapping noise in engine
well in this thread 3 times I asked for which relay is to the glow plugs and either no one knows or no one can be arsed to say so give upOriginally posted by schrodingers-cat View PostThree day`s later. Silence.
NO MORE MR NICE GUY!
I recall it being in the engine bay - maybe near the air filter. Although I may have just made that up. It's the relay that's connected to the glow plugs, anyway.Originally posted by Diesel Turbo View Postwell in this thread 3 times I asked for which relay is to the glow plugs and either no one knows or no one can be arsed to say so give up
You're either very lazy or not very observant.
Open the bonnet, prop it open, and look at relay shaped things around the engine compartment. You'll see a relay with Glowplug relay written on it in yellow print. This is believe it or not, the glowplug relay.
To help you find it quicker, it's NOT hiding anywhere under a cover or inside a fusebox.
Off you go.
I believe so. We seem to keep going off on tangents here. If I recall correctly. this thread is about a tapping noise.Originally posted by gwh200 View PostOh that explains it...only four or so pages ago, I seem to remember him saying it was fine starting from cold, but took a few seconds when hot...is this the case?
