Originally posted by Albannach
View Post
tapping noise in engine
ok
I put the injector cleaner in and BINGO, I went for a 50 mile run out, 100 round trip and its as sweet as a nut!
It still fires up instant when cold but takes 3 seconds when hot? why does it not fire up the same hot as when cold? It is not sucking air anywhere and fully serviced?
NO MORE MR NICE GUY!
any ideas welcome, I have put redex through to help with the injector but it was like this before, The timing marks are all bang on too, cant be back flow as it fires up instant when coldOriginally posted by Diesel Turbo View PostI put the injector cleaner in and BINGO, I went for a 50 mile run out, 100 round trip and its as sweet as a nut!
Hmm
I have read about this on some but would this only effect it when hot? I thought that if that was effecting it it would be same on cold too? as it uses fuel it creates a vacuum I guess your thoughts are, I will try it, then if it works I will drill a small hole, thanksOriginally posted by Sancho View PostTry it with the filler cap off.
It's possibly not that it's hot as such, but that in the act of getting hot, it has been drawing fuel. I'm not saying it's going to be that, but it's a free and easy thing to test.Originally posted by Diesel Turbo View PostI have read about this on some but would this only effect it when hot? I thought that if that was effecting it it would be same on cold too? as it uses fuel it creates a vacuum I guess your thoughts are, I will try it, then if it works I will drill a small hole, thanks
Im going to try it as you said easy and cost nothing, could be right! thanksOriginally posted by Sancho View PostIt's possibly not that it's hot as such, but that in the act of getting hot, it has been drawing fuel. I'm not saying it's going to be that, but it's a free and easy thing to test.NO MORE MR NICE GUY!
No that cap off did not work :-(Originally posted by Diesel Turbo View PostIm going to try it as you said easy and cost nothing, could be right! thanks
I do know that the longer that it is left when hot the harder it is to start, if I turn it off and then back on within a couple of minutes it is fine but if I leave it 30 mins it has to turn over and over? I guess the time gets longer until its equilibrium and then gets shorter again as engine cools until instant start when cold....any ideas? thanks in advance
