diesel consumption
  • #31
    Originally posted by Maverick
    You'll probably find that although your speedo reads MPH your trip meter and odometer are still recording kilometers. Mine are, and like yourself I get between 400 and 424 per tank, but that is km's.
    I would love to think this is the case but its 45 miles to work in my other car.. and its 45 something to work in the Surf... so something tallys up.. now I am confused lol
    -=I swear to drunk I'm not god=-
    • #32
      Mph And Kph
      Youre right Maverick, my speedometer is in MILES and my odometer is in KILOMETRES.
      Thought I was going daft until I realised.
      Kevin
      [SIZE=7]The Crafty Carper[/SIZE]
      • #33
        Just been out for a little spin - down to Essex.
        Got 30 mpg with the aircon on most of the way, and that's at about 70mph. No way am I gonna complain about that!!
        [SIZE=2][COLOR=White]You can't have everything. Where would you put it?[/COLOR][/SIZE]
        • #34
          Since i had my head replaced (on the surf) i have been getting 550km per tank or 10km/li. Not bad me thinks, but not worth the 2000.00 expense.
          • #35
            Just wait until we get your Turbo working properly then it might come down a bit.
            • #36
              As I can't be doing with these funny foreign ways of measuring I did the maths and I am getting 23mpg on a 2.4 ssr x auto calculated over 3 tankfulls.
              This appears to be on the lower side of "average " consumption so I have just added injector cleaner. See how it Go's.
              A positive attitude wont solve all your problems but it will annoy enough people to make it worth the effort!
              • #37
                Well, my two penneth is that we took the caravan out for the first time two weeks ago. I filled up with fuel on Friday aft, (£40) left Blackburn to Bolton then straight to Stransall. Only one diversion then back home to Bolton and needed to fill up again! Did 329 kms to a full tank, thats... erm.... 204 miles!!! .......60mph all the way, even up the hills on the M62!
                Correct me if I'm wrong, if we call fuel £4.00 a gallon that means £40 equals 10 gallons. So 200 miles works out to 20 mpg, I think.
                I may try these additives and see what happens, on the usual commute I only get around 400kms, but then I do have a rather heavy right foot!
                Damian
                http://www.themudlife.co.uk
                • #38
                  Up the pressure in your tyres to around 32-33 PSI. If that doesn't give few extra mpg you can try manual locking front hubs...
                  • #39
                    in my first few weeks of surfing i have been at 22-25 mpg fairly consistently. Quite impressed considering i cruise at 90 on the mway with the air con blasting cold air at me
                    Regards,
                    alex
                    • #40
                      Hi All,
                      Well i have owned my 92 SSRX for just over a week and i must say i'm very dissapointed.I have worked out it is doing 16-17mpg mixed driving! ie i put £20 worth in and got 150klms=94miles out of it the car has only done 71000klms=45000miles and does not throw any black smoke out.Surely this can't be right for a 2.4tdiauto my previous Range Rover fitted with a 2.8tdi mated to an autobox used to manage 28mpg@80mph and that's 500kgs heavier! Oh and another gripe do any other Hilux owners find the driving position to be a bit cramped,or is there any brackets you can buy to higher the drivers seating position? Please any advice on the above subjects very very much appreciated.
                      cheers,
                      chaz.
                      Cheers,
                      Chas.
                      • #41
                        Hi All,
                        Well i have owned my 92 2.4 auto SSRX for just over a week and i must say i'm very dissapointed.I have worked out it is doing 16-17mpg mixed driving! ie i put £20 worth in and got 150klms=94miles out of it the car has only done 71000klms=45000miles and does not throw any black smoke out.Surely this can't be right for a 2.4tdi auto my previous Range Rover fitted with a 2.8tdi mated to an autobox used to manage 28mpg@80mph and that's 500kgs heavier! Oh and another gripe do any other Hilux owners find the driving position to be a bit cramped,or is there any brackets you can buy to higher the drivers seating position? Please any advice on the above subjects very very much appreciated.
                        Cheers,
                        Chas.
                        • #42
                          Hi All,
                          Surely someone wants to talk to me? to add to my previous post i had my mate follow me yesterday and he said my Surf was chucking out black smoke most of the time.I must admit i never noticed myself probably due to the tinted rear window, can anyone throw any light on this i know it's down to overfueling but why? I am about to change the air filter am i right in saying it's the same filter that fits the1990 4.2 tdi landcruiser as read somewhere on one of the Toyota forums? Please as always any advice very much appreciated also any advice on the seating brackets will need a wheelchair soon if i can't sort it?
                          Cheers,
                          Chas.
                          • #43
                            I't a bit quite on here today, a badly blocked air filter will indeed cause overfuelling and resultant black smoke. AFAIK the air filter is the same as that fitted to the 3.0l uk 4runner, eitherway any decent motor factors will have no problem matching one up for you, just be sure to bring the old one along to check.
                            With regard to the seat, I'm sure someone on here mentioned raising their seat before, try a search or hang on and hope they see this thread.
                            Maurice
                            • #44
                              Have a look at this thread about seating position
                              http://www.yotasurf.co.uk/forums/sho...ght=seat+raise
                              Maurice
                              • #45
                                Best place for filters (oil, fuel & air) is probably Milners. Got mine at the Beaulieu 4x4 show for £12+VAT for all three. Usual price is about £15+VAT.
                                Mike G
