i`ve got a 2.4td surf and had it for 3 years with no problems,recently the top of the radiator started leaking which i`ve now repaired,but i noticed it was still loosing water,i`ve replaced the rad filler cap and the thermostat,i checked the oil when i serviced it it was clean and i can`t see any sighn of water,one thing i have noticed is that the bottom of the radiator is cool or cold is this right or could there be a blockage,i`m baffled as to the water loss any suggestions would be greatly recieved.
water loss? baffled
Sounds like a blockage or an airlock to me. I think it would be good to drain and flush the system and then refill it slowly. You may want to use Radflush in it as well.Originally posted by Reddogi`ve got a 2.4td surf and had it for 3 years with no problems,recently the top of the radiator started leaking which i`ve now repaired,but i noticed it was still loosing water,i`ve replaced the rad filler cap and the thermostat,i checked the oil when i serviced it it was clean and i can`t see any sighn of water,one thing i have noticed is that the bottom of the radiator is cool or cold is this right or could there be a blockage,i`m baffled as to the water loss any suggestions would be greatly recieved.
Also a good thing would be to change the rad cap and thermostat while you are at it.
The water loss is possibly the water going from the expansion tank if there is a blockage it will expand too much and blow out of the overflow pipe.
what mileage is on your surf .the radiators do block up but normally only on high mileage vehicles.anything from 100000 miles onwards.take the radiator out and see how fast water flows through it and see if any dirt comes out of it,should give you a good indication.if the coolant has never been changed it can solidify in your radiator and on the insides of your hoses.if you squeeze the pipes you can often feel the solidified coolant cracking off the inside of the hoses,its usually worse on the bottom radiator hose and the heater hoses.hope this is of some help
