the truck is creating a vacuum in the fuel feed into the fuel filter when the fuel level drops it gets worse i've checked the filler cap and put a small hole in it, when the vacuum is created and you look at the fuel primer it has been sucked in and is touching the top of the filter housing, if i then release the vacuum by undoing the union it returns to its normal position and normal running resumes until it does it again, now then does the surf pickup pipe in the tank have a filter on the end, i have also read that the tank breather has a one way valve on it if so where is it, when the vacuum is present in the feed line i have removed the filler cap and there is no hiss so the vacuum isn't in the tank it is only either the main feed from the tank or the fuel feed return possibly any other ideas anyone?
i'm just about to go and blow through the lines back into the tank and see how that prevails i will let you know the outcome
