Hi Guy's and Gal's.
Need help. The 4WD wont engage on my 2.4 ssr, The 4wd control unit clicks when I press the button on the high low shifter. There is vacum at the actuator on the transfer box so I know there are holes in any of the pipes. The light on the dash does not come on and the solenoids do not seem to be getting the comands to operate from the 4wd control unit. I assume it is an electrical fault but do not have a comprehensive wiring diagram. Has anyone got one or have any idea's as to the problem that I havn't thought of or tried.
Thanks in advance
Pete
Need help. The 4WD wont engage on my 2.4 ssr, The 4wd control unit clicks when I press the button on the high low shifter. There is vacum at the actuator on the transfer box so I know there are holes in any of the pipes. The light on the dash does not come on and the solenoids do not seem to be getting the comands to operate from the 4wd control unit. I assume it is an electrical fault but do not have a comprehensive wiring diagram. Has anyone got one or have any idea's as to the problem that I havn't thought of or tried.Thanks in advance
Pete
