Clonking noise
  • Clonking noise
    I have a 1992 2.4 surf, and when I turn on full lock only, I get a kind of horrible clonking noise. It only happens on full lock, now I've just got a new mot, the only advisorys I got was all my ball joints need replacing in the future, They did one for me due to excessive wear, but the others have got some life left in them yet.
    I've been told that all surfs do this and it's nothing to worry about. is this true? if so, does anyone know what is causing the noise? as harmless or not, I would like to sort it as it's annoying, and a tad embarressing.
    Born a free spirit
    You have 4 nylon / plastic caps that wear through on the steering stops, if you put your Surf on full lock you will see where they hit to stop the steering going any further (I hope I'm making sense). Put some grease where they touch, there are 2 located at the front and 2 behind the wheel.
    If at first you don't succeed.........give up.
      Oh right! thanks for that.
      Born a free spirit
        a quick cheap fix
          I guess I didn't get up early enough to answer this one first hehe.
          peace
          cal
          www.thecellardwellers.co.uk
            Sonds like it's a common problem.
            Born a free spirit
              roughtrax sell replacements Plastic Steering lockstop cap
              Show me where the trench is at or can i make one!
                Thanks for that!
                Born a free spirit
                  im getting a nasty clunky grindy noise on full lock. i have replaced both outer cv joints as a matter of course coz they were shot but am now thinking those steering stops need adjusting any ideas about what length they should be ?????????????? oh its a 1990 ln130
                    just put some grease on the stops as they should already be at the right setting
                      No need to adjust them, just put a generous dollop of grease on them
                      Bugga gotta type faster
                        will try the grease thing tomorrow BUT does the steering stop noise sound like a knakered cv joint noise if ya know what i mean
                          on full lock it is a metal on metal grinding noise and is normally loud
                            yeah sounds like the cv joint has sh@t itself
                              just give all the stops a good dollop of grease.
