I changed my brake pads the other day, and it was really simple to change them, but two things, 1st... the wheels would not come off the register, there was a slight corrosion of the alloy to the hub and they would not budge 28lb hammer on the tyre a few times did the trick, all cleaned off now and greased up, they will come off easy next time, so be aware that if you don't clean them up and grease, it could be a nightmare if you get a puncture anywhere other than at home with a big hammer at hand.
Also when ordering pads from Milners, I also bought the pin and spring kit, they may fit the early surfs but the pins are to short for the 1992 model, I had to use the old pins and spings.
