my engine is making a random and inconsistant clanging/crunching noise! when looking underneath there is nothing that seems to be out of place etc, normally when turning or if the engine is revved hard (never more than 2750rpm) for pulling away etc it will make the noise. i thought maybe something was on its way our so i thrashed it off road to see if i could break whatever was going to but i lost power steering for about 5 mins??????? did it its worse today when pulling out of a junction on a hill.....sounded like something has broken off and is banging around the bottom of the engine block? the noise seems to be louder drivers side nearer the foot well. i recently changed all my gearbox/transfer/diff oils but couldnt do the front one as it was too tight... there is a load if black mud/ dirt under front diff but its not sure if i should rule out the front diff being desperate for a change??? not sure where to start without taking it to TOYOTA! which should be a last resort... its a LN130 2.4 manual on a K plate!!! any suggestions are most welcome as i haven't a clue where to start looking???
thanks all
thanks all
